lewis15498;1376363 said:Actually dumbo, you fail. Its not a socket. According to the tsrm, you need a special tool. (SST 09043-3810 from the dealership) or you can use a standard allen key bit on a 3/8 ratchet. 10 mm if I recall correctly.
EDIT: Hes taking the head off b/c he dropped a valve while working on it. I'm pretty sure he has the cams out already.
Good call forgot about the cams:nono:
Thought the head bolts were a 14mm. Or is that just the ARP ones?
