valve stem fell...keeper question
rayall01
901
Westfield, ma
Just got home from Jeff's house. Man was it hot! I haven't got the energy right now, to post my pics. I originally was going to video it, but kotu didn't show up to be cameraman, and it was too cumbersome trying to do it while working, so we opted for photos. Bad kotu, no soup for you!
I didn't anticipate the flexibility issue, so it took us a little trial and error time to overcome it. Now that we have the exact method to do this, I would dare say it would take about 5 minutes, if you prepared everything in advance.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
cinciguy89turbo;1376809 said:
umm so basically its a compression check...
Similar but not quite. A compression test measures the amount of pressure a cylinder can create. A leakdown tester measures the percentage of air escaping from the cylinder. If you pass a compression test I wouldnt worry about it.
kotu100
1,899
Easton, Ma
congratz on gettin it done guys.
sorry i couldnt show up, was having tip problems with my welder, wasted a while 3 hours this morning welding the shit when it should have only taken 30 mins.
rayall01
901
Westfield, ma
Tough, still no soup for you!
lewis15498
Sep 28, 2008
1,397
I want to apologize to everyone for some of the comments I have made in this thread. While I am pleased with the outcome of this project and proud of our accomplishment, thats no reason for me to post egotistical "I told you so" type comments. That is not mature behavior and I apologize to everyone who read them.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Well, I'll be damn ;)
I honestly didn't think it could be done in any reasonable amount of time. That is an innovative way of getting the valve back in place. Nicely done!
Jeff - Why don't you go here and post a detailed set of instructions on how to do this:
http://www.supramania.com/forums/articles.php
It will be a lot easier to search vs getting buried in this section over time. Only suggestion I would have is to feed rope into the cylinder once you have the valve back where it should be and turn the crank to secure it while getting back to the original objective.
Again, nice work...that will save a whole lot of work if someone does this.
cinciguy89turbo
Zero to Sixty
Apr 7, 2009
139
Cincinnati, Ohio, United States
I can't believe this thread turned into what it did. For a minute I thought it was going to become an all out war!
Just wanted to thank everyone for helping me out with this. Its nice to have such a group of helpful folks. And a special thanks/hats off to Rayall and Lewis you guys are pretty much the shit for going so far out of your ways to do what you did haha! I'll keep everyone updated.....
rayall01
901
Westfield, ma
That is certainly what we would have put in the DIY, jdub. There's no pics of it because Jeff isn't worried about that engine, and so we didn't go that far. I for one, wanted to get back to air conditioning.
lewis15498
Sep 28, 2008
1,397
Definitely. When we were finished we brought the piston back to TDC to keep it from dropping again.
lewis15498;1376862 said:
You would have rope in the cylinder so you would never be in this situation, but seriously, if some one asked you to help them get a valve out of their cylinder you would rather pull the head than do this?
If an engine needs valve stem seals 99.9% it needs a valve job as well and sorry I don't half ass things ever it's just not worth it for me to work that way as you end up doubling up on the work sooner or later.
lewis15498
Sep 28, 2008
1,397
I wouldnt consider this method as half assing it, because the OP's original intentions were to just replace the valve stem seals, so this method is just getting him back on track with what he was doing before. OP's question was how can I get the valve back, not should I get a valve job, however i can see what your saying.
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
dumbo;1376270 said:
I hope your kidding, how would you get a hook down there? You know the diameter of a valve tem?
"IF" the valve stem is stil in the guide you can reach the end of the valve head THRU the spark plug hole - not thru the valve guide hole---
rayall01
901
Westfield, ma
Thanks jdub!
