Caught a sweet break today, guy didn't go on vacation yet at the machine shop and finished up my rods! Block will go back together tomorrow.
IJ.;1088128 said:That head looks VERY rough for 30ra......
Painting inside a block is a bit of an old school thing believed to aid the Oil drainback... (I don't buy it)
williamb82;1112991 said:yeah, its a special type of paint called "glyptol" as i recall. spelling might be off. i know lots of old school guys that did it and never had probs. its to help speed the oil drainback to the pan. supposedly a sliperier surface then the block. kinda beats trying to polish the inside of the block like the group a motors were done.
Facime;1114237 said:from memory, doesnt that feed the TB/ISCV? Its commonly deleted and you can just crimp it and weld it shut. I also cut the coolant nipples off the TB and ISC when I did that.
Facime;1114873 said:I could be wrong, its been a while since I even looked at a 7M, but if nothing else is in that circuit then it shouldnt need to have an in/out direction to flow. Its an auxiliary circuit with one purpose and thats the TB/ISC. Unless there is something else in that circuit Im not remembering. The heater core circuit is much the same way, its blocked some of the time.
EDIT: just looked at the TSRM and there is nothing else in that circuit, and in fact the diagram shows it joins the flow downstream of the heater core. I see no logical reason that cant be deleted entirely, much like the heater core can be for those going for hardcore weight reduction.
IJ.;1120744 said:Don't forget to put the Water Hardpipe on BEFORE the exhaust manifold![]()
Doward;1120895 said:Damn you are running WOT with this thing!
Where are you getting your stuff sandblasted? I've got a couple of small items I need blasted, and I don't feel like going to Ocala to do them![]()
