gtsfirefighter;1268635 said:That harness sure is purty. I've got a 91 automatic and should really splurge for one, if they have it.
Adam, are you going to have this on the road this season. I've waited patiently for two winters and then some and I really don't know how much more I can stand. Honestly....:biglaugh:
Adam, are you going to have this on the road this season? I've waited patiently for two winters and then some and I really don't know how much more I can stand. Honestly....:biglaugh:
JDMMA70;1268633 said:yes i amPre89, i found a some what good condition 91 harness that im going to use to make my exsisting harness like new
I would love to have that black cover that goes across the valve covers.
I hope someone starts making harnesses, like they do for the Z, and old muscle car guys.
adampecush;1268671 said:It really wouldn't be that tough to make your own harness actually. I sourced most of the pins used on our harness, as well as the proper crimp tool for reasonably cheap. All you would need is a lot of wire, connector bodies scavenged from other harnesses/junk yard, and some patience.
mk3forme;1268783 said:would you mind telling us where you sourced the pins, connectors and crimp tool from?
adampecush;1268802 said:
miekedmr;1285423 said:Was the plate travel non-linear before?
It looks the way the black piece was slotted into the silver one that were made to swing the silver piece faster as you get closer to WOT. I see that kind of thing on a lot of cars.
sthmstr;1288654 said:Fantastic restoration!!! Great work!!
Do you happen to have a link for the rear brake conversion?
mobes;1289666 said:Oh I understand, and I concur.
I finally added a Deutsch connector to that wire near the starter.
adampecush;1289654 said:not really, I just kind of made it up as I went along. It really helps to have a machine shop at your disposal. If you want, I can list everything you need to have made/purchase to make the conversion work.
