Took the car for another drive last night.
the idle seems to have richened up - looks like I had to give the ECU some learning time. adjusted the TPS down to 0.4 mm, and the bucking problem improved, though its not completely gone...I'm going to try 0.3 mm and see how things go.
Broke in the brakes, but with my current lack of alignment, things got a bit hairy. God damn the car stops hard. Car is going in for alignment later this week.
Found out the car was hitting fuel cut due to the WG arm hitting the turbo support stay, fixed it and now the car is running ~11.5 psi off the WG.
Car is idling at 19 in Hg when warm, 17 cold.
AFR is ~10.3:1 in boost - going to have to deal with this next, but it shouldn't be too difficult.
stick around for more pictures and videos when I finish assembling the interior.
