Jaguar_5's 87 Turbo Build
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Hehe, he sure didn't :)
Check out the clog:
I'm surprised it started at ALL!
Planning on doing somewhere in-between a hard and soft break-in, I'm going to give it heavy throttle runs and hard engine breaking, but I'm going to avoid boosting as much as I can (so no high revs)
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Almost...
Fuel system is all put back together, pressure INSTANTLY shoots up to 40 psi when I jump FP and B+, there was a bit of a leak but thats all taken care of and I'm about to try and see if I can drive it for the first time in over 3 years :D
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
Nice work! Can't wait to see this going man.
jdub;1121736 said:
At least you didn't have to drop the tank!
Bah! I've had to drop my tank with a cresent wrench and a screwdriver before. Had a half tank of gas and no jack (and if you've seen my car you would understand how that could cause some problems). Still managed to get the fuel pump changed in just over an hour lol.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
That is true, but it is frustrating when more problems keep poking up!
I did manage to get the car to idle, and drove it a little bit
The idle was very loopy, but did eventually settle down... There is major hesitation when I give throttle, the clutch engages SUPER quick but I just need to get used to that. There is also major driveline noise that sounds like it's coming from the rear tires, the car is not driveable yet :(
I'm worrying about seating my rings properly if I have to do all this debugging!
AFR's once idle was somewhat stable, were between 10-12, so definitely rich, did see it go as low as 7.5 when the car hesitates and almost dies.
Cold start pressure was at 80, later before I finally shut it off it was idling at about 30 psi, I was pulling 20 in/hg of vacuum, and for some reason the BOV stays open :aigo: it was fluttering in and out when the idle was looping
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
A few more diagnostics:
I have code 24 and 32, I know 24 is normal with Maft-Pro, but 32... well I remember disconnecting the HAC sensor, although I've done so many things I could forget such a small task. If it is disconnected as it's supposed to be with the Pro, will it still throw a code?
Source Definition: TPro500 Vehicle0 and 1.xdf
Constants
Vehicle Select 00
Number of Cylinders 6
Displacement 2.96 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Load Source 0x00
Barometer Comp Mode 01
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 1 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale 0.00
Volts Out 1 Limit 2.45 limit
Volts Out 2 Limit 3.53 volts
Afterstart enrichment 0.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
FE Smoothing 30
SparkBase 15.00 degrees
Boost control TPS Spool 2.50
Boost control RPM Spool 3008 RPM
Boost control TPS Start 3.70 Volts
Boost control PSI Start 5.00 PSI
Boost control DC% Start 25.20 Percent
Boost control PSI Set 10.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 4.00
Boost Control DC% Start Aux 10.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min Load 166.50
AFR correction lean limit 10.00
AFR correction rich limit 10.00
AFR correction gain 4.00
AFR Aux % 0.00
AFR Tracking, Enable delay 0.00 Seconds
TPS Enrichment 0.40
TPS Decay 0.60
Throttle Body Size 6
TPS MAP Max 104.06
MAP Enrichment 0.10
Boost Enrichment 0.10
MAP TPS Min 0.80 Volts
MAP RPM Min 2560.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
MAF Limit RPM Min 0.00 RPM
MAF Limit Time 0.00 seconds
Part Throttle Tracking Idle TPS 0.00
Part Throttle Tracking Idle RPM 640.00
Part Throttle Tracking Idle A/F Ratio 13.50
Part Throttle Tracking Cruise TPS 0.00
Part Throttle Tracking Cruise RPM 2560.00
Part Throttle Tracking Cruise Load 91.05
Part Throttle Tracking Cruise A/F Ratio 14.50
Part Throttle Tracking Lean Load 84.55
Part Throttle Tracking Lean Delay 10.00
Part Throttle Tracking Lean A/F Ratio 16.00
Part Throttle Tracking Gain 15.00
Part Throttle Tracking Startup Delay 74.51 Percent
Enhanced TPS RPM threshold 4800.00
Enhanced TPS Load Threshold 188.24 KPA
Jag: I've posted many times in the past that rarely is a Mk3 in any condition to attempt a hard breakin after an extensive rebuild....
There's always so much debugging to be done, I go fairly gentle on mine and it seals up just fine so I wouldn't stress it.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Ha, well isn't that the truth!
So next time I idle the car should I let it warm up abit so I can set the timing?
And how about the BOV opening at idle? That concerns me...
I'm not looking forward to debugging that driveline noise most of all though :(
I wouldn't let it actually idle for too long at a time.
Jazz the throttle a little and keep actual idle time to a minimum, rich at idle now ISN'T going to hurt too much as it washes the bores but this also helps prevent the bores glazing up (breakin is controlled wear)
Not sure on the BoV can you tighten the spring?
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
It's a tial, so no :(
I can only replace it with a stiffer spring, but what kind of spring would cause it to open at idle?!
Also one of my couplers is abit to large or something and I'm not sure if it's sealing properly.
So do you avoid setting exact timing until after the first few runs?
Once it's at operating temp I shut it down let it heatsoak for a few minutes hook up the timing light ready to go refire it fast idle to stabilise the temps then let it idle long enough to set the timing. ;)
The BoV might just need to be fully opened a few times to seat correctly.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Thanks guys
I think I figured out the driveline noise, I feel like an idiot I don't know if I can say what it was :cry: pretty embarrassing :biglaugh:
I have a few tweaked settings I'm going to try out on the Maft Pro, and this time I'll actually remember to log the run!! I just need to let the laptop charge for a bit longer first.
