That is true, but it is frustrating when more problems keep poking up!
I did manage to get the car to idle, and drove it a little bit
The idle was very loopy, but did eventually settle down... There is major hesitation when I give throttle, the clutch engages SUPER quick but I just need to get used to that. There is also major driveline noise that sounds like it's coming from the rear tires, the car is not driveable yet
I'm worrying about seating my rings properly if I have to do all this debugging!
AFR's once idle was somewhat stable, were between 10-12, so definitely rich, did see it go as low as 7.5 when the car hesitates and almost dies.
Cold start pressure was at 80, later before I finally shut it off it was idling at about 30 psi, I was pulling 20 in/hg of vacuum, and for some reason the BOV stays open :aigo: it was fluttering in and out when the idle was looping
