Time for a sad update
Last night I fixed my idle problem, I tried to adjust my tune back a bit since I now have less air entering the system then before, so obviously I had to re-tune, but I guess I should have just reset and started over!
I hopped on the freeway to get a data log (the car was still driving fine unless I gave it too much load and it went way rich, like 9 afr) and out of nowhere it started stuttering and bucking like crazy, the tachometer was jumping up and down erratically, I pulled off and it died. I loaded the initial setup bin, and managed to limp it to my parents house.
Today, I went back over, fully reset the Maft-Pro settings, fully closed the idle air screw (found out this was my problem, previous owner must've adjusted it), reset the ECU, looked at plug #1 which had a lot of carbon on it, but the electrode looked clean, and gave it another shot.
It drove just fine until it warmed up, then the same thing happened again, this time it kept dying and I could NOT get it home! Had to call AAA
I'm suspecting 3 things at the moment:
1. My spark plug wires, they seem to make a pretty poor connection at the coils, especially #6, I'm going to order a new set from Toyota, like I should've done to begin with!! Don't get OPParts plug wires
2. Spark plugs - I think I fowled them from running too rich
3. Timing - I need to move the CPS one tooth
What's throwing me off is it ran pretty damn well when it was cold! I'm done for today, I'm too frustrated to work on it.
Besides that I still need to fix:
1. Coolant temp sensor, but the rad and upper rad hose heat up, stay full, and the overflow tank fluctuates as it should so I'm not concerned for now - except the ECU also isn't getting a signal, so that might cause issues?
2. Miniscule oil leak on one of the filter housing fittings
3. Speedometer - fine on the transmission, moves a little bit when I tightened the dash in, but it stays below 0 and I can make it jump around faster when I push the dash in, I can hear the cable clicking as it turns, so it's just not making a connection, but my dash is not going in any further...
The bugs keep getting bigger it seems like
