americanjebus;1158890 said:Your idle looks fine, but it does kind of look like you have a miss or something. Mine is a smooth 2.8v all the way across.
Your part throttle looks alright as well. When you do hit open loop the vf will drop to zero, from there i just pull values from the ve table for those areas to where its ~2.5 again. You'll notice a small spike in your graph on the change over once you start to adjust higher up on the table.
I don't think there was a single miss in that graph of my idle, it will switch between 2.5 and 3.75V without missing - BUT when it does miss it is usually when it switches, so it is what's causing it, but not always...
I disconnected my nbO2 sensor and played with some P/T tracking... well it seemed almost like it reset my base tune with the way that it was running - I've decided it's too early for this, and after doing more reading on tuning, I've decided to change my approach a little bit, update the Maft to 5.11, reset all settings, and start over!
This time instead of directly playing with the VE table (smaller more specific changes) I should just use start over with the default VE Table #2, then use the user tunes to tune, and then I will use Rogue's VEMap Utility to generate the VE map automagically! Then I zero-out the UT's and can continue with the small tweaks - and then I can enable P/T Tracking (which does seem like it will work like a charm!)
Attn Maft Pro users:
I have discovered a new program (developed for megasquirt) called MegaLogViewer that allows us to replay our datalogs much more easily!!
Just export the csv from TunerPro of the log you want to run, and import into MLV - It is mostly functional, but there are a few small quirks
To fix most of this quirks, I've created a small utility that will add a timestamp, clean all the labels, and erase unused data - as soon as the SME approves it you can find it in the Piggyback forum! If you want it before then msg me
