Why did YOU go 1JZ?
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
MKIII N00b said:
yeah i typed in BIC mounts and it brought me to some irrelivant (sp?) site that had nothing to do with cars...
Maybe you should have tried "bic motor mounts" or "becauseican mounts" or even "becauseican motor mounts."
Put some effort into it...
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
MKIII N00b said:
you said, swap a 6 speed...does anyone here have a 1jz with a 6 speed, and when you say 6 speed you are talking about teh mkiv getrag right?
it is verry possible to do 6 speed you just have to re gear your final to make all 6 speeds functional!
Manual Transmission Specifications (R154)
Gear ratios ---->
Reverse 3.18
First 3.251
Second 1.955
Third 1.310
Fourth 1.000
Fifth 0.753
(((THE GEAR SPAN IS 2.498)))
6 Speed Manual Transmission Specifications (2JZ-GTE)
Gearbox V160 (5/93 - 8/97) V161 (9/97 - 12/02)
First 3.827 3.724
Second 2.360 2.246
Third 1.685 1.541
Fourth 1.312 1.205
Fifth 1.000 1.000
Sixth 0.793 0.818
Reverse 3.280 3.192
(((THE GEAR SPAN IS 3.034)))
SO ANY IDIOT THAT TELLS YOU THAT YOU LOOSE FUNCTIONALITY WITH A SIX SPEED IS FULL OF BULLSH!T!!! F.T.R.
COMPARE THE GEAR SPAN BETWEEN THE TWO IF YOU DONT BELIEVE ME THE ONLY REASON IT DONT WORK IS BECAUSE SOME PEOPLE BOLT IT UP WITH A FINAL GEAR RATIO OF 4:30 INSTEAD OF WHAT IT SHOULD BE (((3:20))) STOP BASHING THE SIX SPEED UNTIL YOU PUT ONE IN CORRECTLY!!!!
