Ok, this non-sense about its expensive to build a 1JZ because it says 1JZ instead of 7MGTE is garbage. Its expensive to build anything! I can probably spend more money building my lawnmower motor then your motor but it doesn't prove anything. Reliability is souly depended on its owner. Any owner who beats on their car and doesn't expect something to break should just stop while they are ahead. With any car if there is poor maintinence there will be poor performance. If you do not do what you are suppose to and maintain it, it will not be reliable.
As for the thread starter, you choose what you want to do. I advise READ READ READ READ READ! Read the truth about any engine you choose by doing research. Don't believe some schmucks post because you think he is smarter then you ( no pun intended ). I have read almost every page i can find out swapping a 1JZ. I decided the cost and task is do able and i will try to do it in the next few months.
1JZ Cost isn't that much different then the 7M cost in parts. Only big difference may be turn around time thats it. With a little extra cost. For example, and engine gasket kit for the 7M is 350/400 bucks. For the 1JZ its only 150/175 and Jay marks toyota has them. Plus you can swap parts with the 2JZ. Unlike the 7M needing only 7M parts. You can custom fab but thats another story.
I have two MKIII's. 1 89 Turbo Auto in sig. 197K miles on original HQ. I have another 88 Turbo 5sp with 72 K miles. Rod knock. I guess my 89 is in better engine shape then the 88. But the 88 has a better body then the 89. How is this fixed? 1JZ in the 88 and part out the 89
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have beaten on my 89 almost all year long. I've put 10K+ miles on her. Long trips to AC, NYC, PA, MD and was originally purchased in Boston MASS. I plan on having a 1JZ do the same for me. Just with a different tone and kick to it. I want to experience the twin turbo 7K RPM redline.
So do the following and you will be happy
Take notes, do some math, write down a plan, then execute.
