supra1642;1307811 said:i am looking to get some rims that are 18x8.5 25 offset and 18x10 30 offset. my question is will they fit and what tires would u guys recommend? i know i'm going to roll the fenders already.
SupraClaou;1308160 said:New rims are on the way.....:biglaugh:
Front 18'x8.5' with 20 offset / with tire 235-40/18'
Rear 18'x10' with 14 offset / with tire 275-35/18'
Can I get away with rolling only the rear fenders?
If not....I could also machine the rear offset to 20 max - factory spec
for the rim (14 to 20 offset)
SupraJDS;1308187 said:Well the deal with the previous set of rims I wanted fell apart but I recently found another set.
19X8.5 FRONT, 19X9.5 REAR - offset +22 front & rear
225/35/19 Front, 255/35/19 Rear
How would these fit? Will a fender roll or pull be needed? I will be rolling on stock suspension for the summer
Thanks,
Josh
BorHor;1308164 said:Fronts will fit. Rears probably not. I had 18x10.5 +15 w/ a 245 and it was pretty damn close.
SupraClaou;1308564 said:Thanks for the info BorHor.
So,I should roll the rear fender and machine the rear rim's offset to 20 ET!
I am on eibachs...so it should kind of fit :sarcasm:
If I am still tight,I would go from 275 rear tire to 265 :naughty:
CantWait;1308499 said:Ok so I just got my supra today (87 turbo) and my list of wanna be mods is starting to grow and grow, I found a wheel a like but i would like to run an offset and have some wider wheels in the back, they are available in 18x7.5 with a 40mm offset, and 18x8.5 in both 45mm and 55mm offsets, is it possible for me to run the 7.5 in the front and one of the 8.5s in the rear? if so which one? Thanks
jmcboost;1310188 said:So , How can I find out if I can get my rears machined so the offset isn't so far out (rears are rubbing)?
SupraClaou;1310211 said:Usually you can machine the rim to change the offset a little bit...
But only just a little bit,about 3-5mm.Some rims,like Azev (made in Germany),
gives you a wider range of machining and changing the offset.
Front is 8.5' x 18' with factory offset 18' ....but the dealer says that
we can play from 18 to 30 offset,and rears are 10' x 18' with 14 offset
and we can play from 14 to 22 offset.
Why your rears are rubbing? What rim/tire size do you have?
And have you rolled your rear fenders?
