Wheel Fitment & Question Thread
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
josh930;1118087 said:
I want to make sure the wheels I'm going to buy are going to fit without a problem I'm pretty sure they will I just want some reassurance. I'm also going to be putting on the wilwood 4 piston BBK on the front so I'm hoping they will fit as well.
Blitz type 03 18x9 +38
18x10 +45
Thanks
They should fit pretty decent. I think there is enough clearance for a BBK but if not just throw on a spacer.
SWEEEET 1000 post
MK-111
Wigan
need a bit of info fellas,
got a chance at some 18" veilside split rims rears are 10" wide and should be an ok fit.
but the fronts are 9.5" wide et45, and I ain`t sure if these will work,
if anybody knows for sure it would be much appreciated
natedogr
296
Chatham, Va
hey boris, what size tire did you run when you had your na mkiv rims? and i remember you had some spacers for them too, what sizes were they? i plan on getting some kyb shocks and not sure on the springs yet. i'd like the car to be a little higher in the rear. any suggestions? thanks
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I had 225/50/16 and 245/50/16 and as for spacers I had 23mm in front and 28mm in the rear. As for springs Eibach are nice if you don't want to be slammed.
Turbo Drifter
534
Surrey, BC Canada
Looking at putting togeather a track wheel and tire setup. I want to run 17x10 on all 4 with a 275-295 all round if possible. My fenders are rolled and pulled about 1/4in front and rear. I am looking at getting eather Toyo R888's or Kumho SX's. As far as wheels go looking for somthing light Enki RPF1's or somthing along those lines.
What will the largest tire I can fit be and the best wheel offset to get me there? I have a AP racing BBK.
I have 2 sets of coilovers one is a Racing gear N1 and the other is a custom made set of Bilstines (sp) and race coils.
Thanks,
Jeremy
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Thanks,
Jeremy
I have seen 275 done in front a few time. That is on a 18x9.5 +35 wheel. So getting a sets say RPF1 in 17x10 around +35 should fit a 275 all around. Now as for fatter all around I would't know personally because I have never ran anything so large in front so I can not give first hand experence. So from information that I do know if you want to run the same size wheels and tires all around I would am going to have to say a 17x10 around +35 w/ a 275 tire would be best.
jessetooslow;1125155 said:
depends on what you mean by fit good. Because at the thinest a adapter is around 25mm and the offsets on those wheels are around a +35 I am assuming. So that will bring the offset down to a +10. It can be done with stretched tires and extreme fender rolling / pulling. In the end it can look nice if you want the extreme camber look.
Dutch7m
7m for live
Jun 3, 2007
75
The Netherlands
how will this fit and look like?
SSR PROFESSOR 18inch 9J in front an 10J at the back ET29 and ET37
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
wtf?
i have to see pic's of you pulled ass fender's or are they just choped
garagefujimoto;1138863 said:
This just in:
My car is modded enough that a test fit of 18 X 13's was able to fit front and back LOL
rodel
SoCal
May 19, 2005
2,266
5
SoCal
This just in:
Unless your suspension is modified, then they have to be at least around 0 offset
Either pics or :bsflag:
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
I'll try a pic tonight if I get home while sun is out
18 X 13 zero offset off my Old Celsior
Put both rears on one side.
Coilovers, JIC camber arms, and pulled to the max, not chopped up
The front tires actually turn, but only because I have the fender tubs and even the lips/edges of the bumper/trim shaved for max clearance.
Only problem would be the lower control arm, I have extended rack travel with the GP Sports kit, and the bck side wheel lip hits at about 95% turn
