^LOL that seems to be the question everyone has been asking about once every page for the last 8 pages, which still has not been answered.
Wayne G.;1375247 said:Did the valve fall all the way in and is loose in the cyl.? If it did the head must come off.
cinciguy89turbo;1375253 said:I'm almost 100 percent sure I can't see it with flashlight or anything. I paniced when it happened and turned the crank to see if it would come back up...felt a little resistance and stopped....figured it got jammed...:3d_frown:
rayall01;1375254 said:Damn, I hope it didn't get bent! If that's the case, you will have to take the head off.
HommerSimpson;1375292 said:can you take a small phillips screwdriver about 6 inch long and just slide it down the guide and see if it hits the tip of valve... or goes all the way threw...if the valve is still in the guide.. theres a 50/50 chance you can still get it back up with out removing head...
Wayne G.;1375400 said:Aggreed, a length of (coat hanger) wire bent with a small hook on the end thru the spark plug hole you could work it back up into place -----
rayall01;1376233 said:Less than 24 hours, naysayers.
This is bordering on trolling and wasn't called for in any way DON'T do it again.rayall01;1376233 said:Less than 24 hours, naysayers.
dumbo;1376274 said:Patiencently waiting
But he prolly could of had the head off and on by now.:naughty:
cinciguy89turbo;1376317 said:what the hell kind of socket do I use for the damn studs! It looks like a 14mm. But none of mine fit down in the space provided. Is there some specific socket I should be using?
dumbo;1376347 said::biglaugh::biglaugh:
Take it to a shop, or be very glad rayall is coming, and ask him to bring a 12point socket for WHEN YOU TWO FAIL AHAHAHAHAH
Nah I just kid haha.:naughty::naughty::biglaugh::biglaugh:
EDIT: Or do you mean you physically can`t get it on. If so, take the cams off.
lewis15498;1376363 said:Actually dumbo, you fail. Its not a socket. According to the tsrm, you need a special tool. (SST 09043-3810 from the dealership) or you can use a standard allen key bit on a 3/8 ratchet. 10 mm if I recall correctly.
cinciguy89turbo;1376365 said:You guys crack me up!
