7MGTEsup;1373823 said:How long does it take to undo 14 studs?
It takes a while to get to those bolts, and you ruin some gaskets on the way
cinciguy89turbo;1373984 said:I don't know if this is true for the newer cars, (if you wanna consider 89-90 newer) but my dad (who is 73 and is used to working on pre 80's cars) says that if you overhaul the top end the pressure will end up blowing the bottom. So i'm kind of worried about that. Any insight? I appreciate all your help so far guys
I'm working on my head right now and my next door neighbor, who's ~60, told me the same thing about the higher compression. I told him that as an engine designed for a turbo, it can handle any extra pressure, The 8.4:1 compression helps, too. But if your aiming for higher boost, than you will need to do something to avoid detonation.
rayall01;1374118 said:Hey dopey, you don't put the line thru with glue on it. you put it thru clean, then fish it out the spark plug hole. after that, you use a magnet to fish out the valve stem. Then you clean the tip of the stem and glue the line to the top of the stem, slowly drop the valve back in, and pull the line out the guide. It would be more funny to see a YouTube video of you trying to get yourself out of your locked car. That seems like a challenge for you.
Calm down, you should've mentioned all of that before. But I for one would like to see a demonstration of this, it sounds interesting.
lewis15498;1374377 said:Take it easy guys, I wasnt looking to start a fight here.
Ian you know I got love for you man, but you said it was rediculous, and I'd like to take a stab at it, to see if its possible to do in a reasonable amount of time. I know its not the right way, but when you pull a head you need new gaskets which can be costly. Suppose you pull it off and find that you need to have your head resufaced to put your previously running engine back togther? Not saying this is the right way to do it, but if your flat broke, this could be money you dont have.
Ray, I came up with this idea, you corrected a flaw in it. I will come through saturday, but I'm not coming through for you, I'm coming through for us, so we can prove our case. Teamwork broski!
Who knows, maybe we will fail miserably, maybe we pull it off in 20 minutes. We won't know until we try it. Lighten up guys, its all in good fun.
+1
But if you can't, don't be scared to pull the head. It's a very common thing to do on these cars which means that there's plenty of documention on how to do this on many websites, including this one of course. Undoing 14 bolts sucks, but if it puts your supra back on the road, you gotta do what it takes.
