Sneakypete's Bulletproof Powerplant Build
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
joliroger4;1095443 said:
I use an impact gun on the damper bolt. I am in Dumont around Hackensack. If you are close and you want some help with things, let me know.
im trying to do everything according to spec. i feel if i use my impact gun, i wont know if its too tight or not tight enough. last thing i want is to strip the threads on the crank, or have it come loose.
i will be working on getting the clutch situation straightened out tuesday morning. and hopefully i will be able to drop the motor in friday and mount the new intercooler and oil cooler. your more than welcome to stop by. a few other guys on SM will prob be stopping by. the more the merrier.
thanks
-pete
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
Then you need to fab a crank stop and get a torque wrench that will operate to that value. I use the imact gun and some red loctite to avoid the hassle and I've had zero problems doing it this way. You wont strip or crossthread the bolt if you start it by hand, but by all means, use whichever way you want.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
what i did to stop the crank was put a screwdriver through the hole in the flywheel so when it turns, the screwdriver hit the motor. i read somewhere that using anti-seize lubricant on the pulley and bolt is a good idea if you ever want to take it off.
i guess i will buy or rent a bigger torque wrench.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
pretty much done assembling everything. just waiting for some aeroquip fittings to come in tomorrow for the oil cooler system. got the clutch, flywheel and tranny on, along with the rest of the necessary accessories for the motor to go in. tonight i painted a few brackets and ill pop them on tomorrow night.
still waiting for my suprasport shortshifter to come. its been a few weeks. apparently fedex "lost" suprasports order and jack was gonna get one dropshipped directly to me.. but that was 2 weeks ago.
friday the motor is gonna get dropped in.... for real this time. a bunch of guys here on the forums might be stopping by... if anyone else local wants to come, shoot me a pm.
-pete
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
those belts are a BITCH to put on... there much harder on the supra then they were for my friends eclipse... best of luck to you! and nice build!
when i did my crank pulley bolt, i use a piece of metal that goes from my flywheel to a transmission bolt hole, and that holes the flywheel while i torque that, and then i torque the front crank dampner... worked like a charm to 195! (but going that high is a bitch all in its own) hope that helps.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Using the rope trick to change valve seals is good...using it to torque the crank is bad.
The 2x4 to stop the crank is much preferred.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Not a biggie ;)
195 ft/lbs is not good for the valves...a 2x4 on the other hand doesn't care.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
you have a torque wrench that goes up that high? mine only goes to 100. so i torqued it to 100 for now. the tranny is on, so i'll have to wait till its in the car to torque it the rest of the way (if i can find someone with a bigger wrench).
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
jdub: i have a few questions about the break in.
you recommended using straight 30 weight non synthetic oil. i picked up some non-detergent 30weight from napa. do i want non-detergent, or detergent oil for the break-in period?
should i use the trasko filter during break-in, or just regular wix filters?
thanks
-pete
Grimsta
1,081
Santa Rosa, Ca.
sneakypete;1099920 said:
does anyone know if and what value to torque the power steering high pressure line?
Theres a saying that goes "torque specs are for people who dont know what tight is." Which, eh, is true alot of the time but when it comes to headbolts and rod and main caps you'd definately want to torque those right. A powersteering line though, just tighten it.
As for the Gates belt, its not that bad to get on. You're supposed to LOOSEN the tensioner before you put a timing belt on! ;)
Don't skimp on this go and buy a wrench if you can't borrow one as it has the potential to totally fuck your motor if the bolt backs out in use (and it will at 100 ft/lbs)
I've seen many trashed 7M's with the snout of the crank ruined from a loose damper.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i think tomorrow i will go out and buy one at advanced auto and then return it. i have a good torque wrench, but it doesnt go up that high
update: engine is in. just have to plug in few connectors, mount the intercooler, oil cooler, and new lines, new one piece drive shaft, and some misc piping and wire in the new fans and aluminum fan shroud
