IJ.;1062188 said:What were the Probe issues Pete?
RedEj8;1065236 said:Hmm..I was told by a few engine builders that non-detergent oil is fine for engine break-in. I only used it the first 50 miles after i had done the initial start-up oil change. After 50 miles I changed to 5-30 dino. Worked fine for my engine :dunno:
Whats wrong with non-detergent?
AbsoluteSpeed;1065283 said:Hey pete great build so far.
Where did you get the poly motor mounts and torque damper
and did you decide to get your flywheel resurfaced, or go with the lightweight flywheel?
jdub;1067030 said:Stock bore is 83mm...0.040" over is 84mm.
An 86mm MHG is fine![]()
