jdub;1111249 said:Yes it's normal to burn a bit of oil until the rings seat. You should change it and the filter very soon for the reason you said...the assembly lube and other associated crap is flushed. Change the oil and filter again at the 500 mile point...same straight 30W. Go to a syn oil at 1500 miles and use a good filter (Wix).
Clanking sound? Where is it coming from?
Are you running a thermostat in the cooling system?
IJ.;1111277 said:What's the Hot idle Oil Pressure Pete?
jdub;1111322 said:I assume the thermo switch triggers a relay to active the fans at that temp...Do the fans come on when it's warmed up?
Grimsta;1208985 said:PM me when you wanna do your suspension and wheels. Can you say Volks?![]()
