Post LED clusters and climate controls.
spipedong
Level 2 Rythym Rogue
Apr 2, 2005
404
Eugene, OR
Andre;873035 said:
Blue
download.php
Andre - I love the SAFC2 mount job up above. Did you custom build that? Have any day time pictures? I'm looking for a way to mount an AVC-R that's on the way.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
Kckazdude;919709 said:
I recently changed mine to blue. I still havent found the perfect place for the resistors to knock the voltage down so they arent as bright. I also replaced the 7 segment temp readout on mine. I didnt want to expirment on different plastics and tints to get a good hue of blue. Was easy enough to do. The hardest part was bending the LEDs into shape.
http://img.photobucket.com/albums/v122/Kckazdude/87 Supra/DSC00116.jpg
Why don't you put the resistors in place of the existing ones? For blue you would change the resistors to incease the output voltage as the stock setup is generally lower than what most blue LEDs take to power on. Putting higher value resistors may turn off the LEDs completely.
How does your dimmer switch react to the blue LEDs now? It is probably max brightness or off?
When it comes to electronics, hard/easy is all relative. Most people don't understand how it works and how to modify existing circuits. Personally changing the LEDs and display is simple but I can understand how some people find it to be overwhelming.
Kckazdude
1,239
Memphis, TN
For the LEDs I have, the stock resistor value is just too low. The blue is really bright. Turning the dimmer down to almost off they are almost just right. I havent pulled the CC back to check what is in place yet. One I can pull it down and determine what resistors are in place I will do my math and put the correct ones in.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
Stock
White LEDs
Has some hot spots that would need to be controlled by using a cooler white.
The best part about the white is that you can still see the red accents.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
Hmmmm.........after seeing the white, I'm not so sure anymore. How do you like it, and do you have any more pics or different angles?
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I do like the fact that the white keeps all of the red parts of the gauges looking red, and the needles seem to be easier to see then with other colors. How easy is it on the eyes at night? Do you like the white, or do you wish you went with another color?
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
91supran/a;921986 said:
can you make it so that the numbers are like blue and then the needle is red? or is all gonna be the same?
You can do that with a cluster from speedhut I believe but it costs alot more than buying a few LEDs.
And I haven't "chosen" the white, I just pulled the green sleeves off of the LEDs that were in there just to see. I would like to do blue but don't want to loose the red accents so I think I will try a "cooler" (softer) white. I have not driven the car with the white.
gsmokez
327
Brampton, Ontario
Hey guys I'm having trouble getting the led's because my parents don't trust online stuff but what kind of soldering iron do you guys recommend for this?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Alternatively, you could have used a less bright LED and not have to change any resistors. I used these http://www.eled.com/product.asp?catalog_name=LEDs&Product_ID=E934MBD and they were a nice mild brightness with the stock resistors.
