I was about to explain almost the same after getting back home.
That's also what is explained on te Reg Riener site linked some posts before..
IndigoMKII;1914671 said:Well what you want to do is this, turn out the afm screw all the way or even as much as go mid way. After that you'll want to hook up a multimeter to your vf/e1 ports in the diag box in the engine bay. Switch it over to dc volts and look at the voltage, you want the voltage to be 2.5. My car runs 14.7 afr even WOT til about 3400 rpms then the car goes over to open loop and that's when the afr's dip over to 11.0 and stay there for the most part.
Now this will be a joint effort between the afm screw and your static fuel pressure to get the vf happy. The happier the vf signal is, the less the ecu is trying to compensate for to keep it in the afr range it wants. Now my lex afm screw is still unaltered, it still has the cap covering the screw, so all I did was play with the fuel pressure with vacuum still attached while reading the vf.
The TCCS will not alter anything in open loop mode, this is why most people with a SAFC that know what they're doing, they don't even bother with anything under 3600 RPM's. The TCCS in open loop and WOT basically opens the injectors all the way, which is why the cars run close to 10.0 in the AFR's and why most people will back off the static fuel pressure a few psi. That way when the car does go open loop, it's not receiving as much pressure in hopes to pull the afr from 10.0 to 11.0
If someone sees a mistake in this, especially regarding the location of the afm screw, please correct me. I have no personal experience with tuning with the afm screw as my afm screw cap is still on.
I worded that wrong... but if your here to slap me upside the head for wording... your just wearing out your keyboard. my AFR's are at 10.0:1 at approximately 3500. "Pig-rich". Satisfied?3p141592654;1914790 said:Sees max air at 3500 rpm, huh?
3p141592654;1914790 said:Sees max air at 3500 rpm, huh? The ECU tables are based on load, more accurately volumetric efficiency, which is (measured mass flow per crankshaft rotation / theoretical mass flow). The tables go up to redline and ~100% load, there is nothing special about 3500 rpm.
SC61 MK3;1914788 said:With the walls smooth and no oil control help from the middle ring and a tired upper ring, oil will begin to mix with fuel in the combustion chamber. When this happens, your 93 octane fuel probably hits a value of about 80. Then detonation comes into play and begins to beat holes in the pistons, among other things. "
http://www.laskeyracing.com/shop/breakin.htm
Grandavi;1914814 said:I worded that wrong... but if your here to slap me upside the head for wording... your just wearing out your keyboard.
Actually its pretty straightforward. There is a map versus rpm that is compared against the current engine load. If the load is > than the map value it goes open loop:
2800 rpm 48%
7600 rpm 0 %
So for rpm <= 2800, if load exceed 48% it goes open loop. As the rpm increases, the threshold linearly drops, so at 5200 rpm the threshold is 22%, and so on. You can see that the faster the engine is spinning, the sooner it will drop into open loop.
There is also a throttle check, and if the the throttle is greater than a certain amount (48% to be exact) then it will go open loop regardless of rpm.
There are a bunch of other special cases that come into play, including rpm < 300, right after startup with no O2 sensor cross counts detected, derivative of the load variable, and some extreme odd behavior of the short term fuel trim variable, but those are just covering certain special cases.
3p141592654;1914827 said:I'm here to correct bad information, and what you wrote is wrong. I'm sorry if I hurt your feelings in the process. I've spent many hours figuring out the ecu code, so I know how it works.
As for the questions about when does the ECU go open loop, I will repost here what I have posted elsewhere on the subject.
IndigoMKII;1914858 said:Sorry to go off topic here then, if I go WOT at say 1800 rpm in 3rd gear, why does my afr stay near stoich til mid 3000 rpms? I thought open loop happened regardless of RPM as well but my afr's are saying it doesn't switch over til mid 3000 rpms, or atleast that's when they go over to 11.0
3p141592654;1914859 said:In order to dial in the engine management with the sophistication of the factory ECU, you would need to spend hundreds of dyno hours in a climate controlled room to cover the operating conditions a car sees in daily operation. The stock ECU (25+ years old now) has over a hundred maps and tables to fixup operating conditions for all sorts of conditions and modes, and to extract the maximum mileage and power while maintaining the drivability people expect, keep the catalyst conditioned for good emissions, and respond to a wide range of fuel quality. You will not get that level of sophistication from a standalone. A very common approach with standalones is to throw fuel at a drivability issue, which results in poor overall fuel economy. This is then sold to the customer as the price of performance when its actually the price of a one-size fits all solution.
Anyway, my intent it not to dissuade you from going that route, just that there is no free lunch, and to go in with your eyes open. Weigh the pros and cons carefully.
