kk, Im a little behind you in technology. Not sure what DBW, TRAC, PWM outputs are, etc..
I believe the HKS unit is limited, but you can addon sensors. Not even sure if its the right one for me (still research and learning)
Google is my friend, but experience can skip a lot of humps. In the end, I dont want to go totally overboard cost-wise and I dont want more monitors then I need for a streetable 7M MK3. Im also not looking for maximum HP out of my engine. Just looking for good performance and bullet proof engine stability. The only one I have ruled out is Megasquirt because it is beyond my scope as a DIY stand alone. AEM is almost ruled out because I have not heard anyone refute my belief that it is not dynamic enough for a highway cruise from plains to mountains to coast.
Im not worried enough about detonation to add water/meth injection...
This is probably the most complex choice I have had to make on my car. Without understanding the basics of properly tuning a car, its like reading Greek with a Japanese tutor. Im slowly trying to figure out all the components/functions and application, but its beginning to look like a steep learning curve. My alternative is to trust my tuner it seems (basically explain what I expect, let them advise). I hate making choices without understanding the why's...
What I have looked at (and I may be barking up the wrong tree with some of these)
Infinity-8 Stand-Alone Programmable Engine Management System (not sure what the 8 stands for... )
http://www.aemelectronics.com/engin...one-programmable-engine-management-system-95/
This one seems to have all the bells and whistles and isn't that badly priced... but I cant judge how dynamic it is because of my lack of understanding the whole ball of wax.
I have also peeked at the AEM Series 2 EMS Engine Management Stand Alone system but it seems to be a bit less than what I am wanting (although probably one of the simplest)
ProEFI Pro 128 ECU
http://www.theboostlab.com/store/products/ProEFI-Pro-128-ECU.html
This one looks good as well, but again... I have no brain power to determine if its any better than anything else or if there is issues with it.
Apparently the 48 ECU is all I would need though, as I study it. The 128 is kinda for more car than I own. Looks like a fairly straight forward setup.
HKS F-CON V Pro
http://www.hkseurope.com/electronics/fcon_pro.asp
This is the one recommended to me by my tuner at this point. Bear in mind.. I have the HKS EVC-S boost controller already and the only time I will actually do anything on it is to do a scamble mode for those rare occasions that I want to do a higher boost. Otherwise.. I plan to set it and forget it.
There is a lot out there but educating myself is my first step I think. At least we have some good stickies here for me to peruse.
