SC61 MK3;1915038 said:Apparently one guy in one week can tune a car to drive to better than an entire company with millions of dollars and unlimited resources
External parameters are relearned by the stock EcuGrandavi;1915055 said:2. I like having an engine.. by modifying a stock engine, I am changing the ECU parameters.. (umm.. you know what I mean?)
I can't think a standalone can be as safe as the stock Ecu, it will allow tuning mistakes or failures that TCCS won't . It has been stated some posts ago, Toyota engineer worked hard for that.3. I dont want to do this again.. ever! But.. I also dont ever want to part with the car. So... safe runs.. hard runs. I want to enjoy the car
Rollus;1915058 said:I prefer TCCS+Piggyback than standalone after all the things 3p14 explained in his thread but..
Technology was from decades ago, and actual technology is great: sequential injection and ignition, etc.. It would request lots of programming to achieve all the safety features of TCCS.
I haven't any doubt a standalone can be tuned within one week, as we talk about tuning and setting up.. Does the cost of all this is profitable for this power goal? I doubt.
Grant, if you want fine tune + datalogging, you may have a look at MAFT Pro or Map Ecu. In both cases you will need a laptop (or CarPC? ) for datalogging.
I think a standalone is required when you hardly mod the internals of the engine: bore, stroke, head port, valves, etc..
AFAIC when only externals are modified, a piggyback seems enough. But not a random one, for my project I choose Mapecu, because it can tune fuel and ignition. The cheapest (safc, etc) cannot tune ignition, and as ignition map is trimmed when you trim fuel, then I do want to let the timing as close as factory specs.
It's not even installed yet..IndigoMKII;1915071 said:How far will map-ecu take you though?
No I cannot. Do I want high, medium, low power band? I want medium, because I don't wan't to kick my and mine passenger ass with a high or agressive powerCan you raise the rev limit with it? What about further raising fuel cut with it?
It's why after the BPUs' we upgrade charged air system, fuel system, and ignition (at least sparks) all together no?When you're running a much bigger turbo and you're greatly changing when and how much air the engine is receiving, the timing and fuel might be off for what the engine needs.
It might pull too much timing or not enough fuel. What about if you wanted to go a step further and eliminate the ignition system and run the dh61 igniter? Or even run 12 injectors instead of 6?
It's all about what your future plans are with the engine..
Grandavi;1915055 said:what do you mean? Please expand on that...
I am not seeking to go standalone to say "hey! this is better than Toyota achieved way back in 1988!!!".
Im looking at it because
1. I like having more power.. it feels good and suits the car better
3. I dont want to do this again.. ever! But.. I also dont ever want to part with the car. So... safe runs.. hard runs. I want to enjoy the car.
My post is about, should I go with a standalone, followed by, what are the pros/cons, what are the best systems to use, etc.. I am edumacating myself by asking others and researching the responses.
The AFM issue was included solely because that is how I am running right now and so far, from what I am researching, the best possible way to run is to go standalone simply because its the only way I can alter the ECU's parameters enough and to gain enough engine control to run safely.
at least.. that is what I am understanding to this point.
SC61 MK3;1915090 said:want to run e85
SC61 MK3;1915090 said:The ONLY reasons for going to a stand alone is if you are "maxing" out the capabilities of what the stock ecu can handle along with some fine tuning from piggy backs. IMO it should not even be an option unless you want way more than 500whp, running race fuel and high boost 25+psi, Running very large injectors or want to run e85, or have a highly modified engine wanting to raise rev limiter (e.g. built head w/high lift cams, ect.)
If you don't fall into any of those categories the stock ecu is the safest and most reliable WITH A PROPER SETUP OF COURSE
Rollus;1915093 said:For e85 I think properly sized fuel system and a piggyback (for flex) is enough. Narrow band lambda needs also to be tweaked.
SC61 MK3;1915102 said:Most e85 setups I've seen usually have 1000cc or higher injectors
Grandavi;1915118 said:Okay, this is probably the most appropriate response according to my setup (as seen in the original post). I can't run E85 because I am in Canada.. we dont have it.
I dont want to exceed 500 rwhp, if I get anywhere near 400 I'm smiling. As is (if they dyno was correct) the 300 rwhp with 367 torque is pushing this car damn fast as is.
Of course.. that doesn't mean that in the future I wont go and do that, but my goals are simply a fast, unbreakable summer cruiser. I have never ran a car on a track so I dont have any desire to. My wife pushes me in that direction though because I tend to enjoy speed, so if I ever do.. then the plans will probably change.
From all the info so far, my safest running is with the AFM and accepting 10:1 AFR (or playing with it to get the 11:1 AFR). The standalone may be a bit more than needed at this point and introduce potential for damaging my engine even though it will make it run "faster" and safer at a higher boost.
I am only running the 57Trim CT26 at present and dont want to really put it up past 15 psi anyway. At 12 psi, my present tires (which are brand new) wont hold traction in second under boost (I get a really cool little tail wag).
So, thats the reality. The dream is to go standalone later and really fine tune the puppy, but I think larger injectors and larger turbo would be more appropriate for that setup.
I think I am starting to get my tiny brain wrapped around all this.
Rollus;1915121 said:I agree, and then two cases:
- it is used as a race fuel and there are lots of other mods
- it is on a street car running piggy rich or with a damn short duty cycle.
Going e85 with a stock engine needs 550cc injectors and some degrees of timing advance. that's all and enough. (until the fuel pump is healthy)
Grandavi;1915154 said:I dont think its 2x for E85, but it does have less power than gasoline. The only benefit is the high octane (106?) so you can tune agressively from what I understand.
As for the comment regarding the stock intake/filter... I am running just a paper filter (used to have the K&N, but with my current setup, the AFM wouldn't take the old K&N so I went OEM paper (safest until I think of something different). I dont think the performance gains are that much from running a different filter although I was looking at going with the Apexi one. However, I do not want to draw air solely from the engine compartment.
However, the intake for what I am setup as currently is probably perfectly fine. I doubt I am losing more than 2-5 HP from how its setup (if that). Therefore, its not really a concern.
I do want the bigger intercooler, though, not only for performance, but also cause they look bitchin'... lol. My car is about looks as well as ride.
