today has been a day of driving back and forth with the girlfriend
but meanwhile i had a chance here and there to pick up some stuff.
New exhaust manifold studs/lock-washers/nuts
New Turbo studs/lock-washer/nuts
replacement for the 1 missing valve cover bolt lol
took the 1/8 bspt plug off of my spare engine to plug a oil feed hole that im not using.
everything is mounted temporarily again just to make sure it all was correct
only thing i had a problem with was the upper left stud for the turbo hitting the vband
its ok i had a shorter one on hand
i also received my wastegate flange today, which ended up being a wrong order
so i have to send it back and make sure i get the correct one this time
