An update of the last couple days.
As can be seen from the picture below, the engine is finally in the car. What a pain in my ass. After realizing the hoist boom wasn't long enough and having to remove the bumper support/intercooler/oil cooler, the hydraulic cylinder on the engine hoist we were using decided to give up when the engine was halfway in the car. We couldn't lift the engine, and if we dropped it down or adjusted the angle, the engine mount would hit the firewall, or the widened oil pan would hit the subframe/steering hardlines. After an hour of swearing/trying to pump the cylinder/thinking/swearing, we decided to sacrifice some paint on the oil pan and jack up the rear of the transmission and slide the motor into place. Finally, as can be seen from the picture, the engine found its way in. (not without some f'ing firewall dings though)
so now i've got all of the little stuff to do. Things left include:
Finish oil lines
Install turbo and exhaust
Install boost and WB02 gauge
Fabricate intercooler piping
install intercooler and oil cooler
finish egr system
assemble front bumper
finish interior
fill with fluids
finish HID/stereo/fuel pump fuse box wiring
install driveshaft carrier bearing
torque random bolts
start car!
