I solved one of the major issues with my filter relocation...it previously had a #10 ORB to a -10 AN fitting, which required me to use a -10 to -8 adapter, and then a -8 elbow as I thought I couldn't get a #10 ORB to a -8...well, it turns out they're readily available, and as a result, I gained over an inch of clearance to mount the filters. Depending on the fit, I may still have to go with a #10 ORB to a -8 swivel (which I also just found out are available). Damn hose ends start to get expensive in the bigger sizes...
