I think i still need to move the brake lines from the ABS actuator.
I don't think i will romove the ABS system
I have been debating removing the AC. I know i will not be able to get the customs lines made for it soon. I know that i can't just keep ot there and expect it to work after the winter is over and the ports on top have been exposed to the elements no to mention the insides of the compresor and the fact it has not been used.
I have to modify the plate for the Ignitor since i was given a slightly different one. It seems that all is in order. I should have the car up and runnign soon. Providing i do everything right.
I will be able to use an inpact gun to take the nut off of the crank pulley. So i will be changing the timing belt tomorrow. Or at least i think LOL
I will also be cutting the Whole in the Fire wall tomorow if i can. I do not want to remove the dash from the inside of the car so we will see how it goes.
As for the Engine gasket set and turbo Gasket Set. I have relized that there are some gaskets not included in these set's.
What i have noticed so far is the
- gasket between the turbo oil return and the oil pan area.
- The O2 sensor
that is all that i noticed for the turbo gasket set
as for the the engine gasket set.
- the ISC gasket is not included.
- Throtle body gasket is not included
It is surpising. For the cost of the gaskets sets. you would expect a little more
On the same note all the gaskets are atleast metal
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
which is nice to see
