Blue87T(Dan) said:
Sounds like this will be a great product.
As always, I have questions.
How would the boost control be adjusted? Would it be able to be done with the handheld (for lack of a better term) device. Will you be able to preprogram any triggers to adjust the boost such as TP. In other words, could I set my boost for a level say before 70% TP and once I exceed that could it automatically up the boost to a predetermined level.
heh.....always w/the long questions, eh dan?
boost control (as well as any other function) can be adjusted from the keypad. take a look @ this page to get an idea how you can configure boost control:
http://www.maftpro.com/info.shtml
Blue87T(Dan) said:
Will the software datalog all the parameters it controls when running speed density.
Things like
PSI
A/F(used with a suitable WB)
RPM
TP
EGT(if you have a probe)
VF voltage
Karmann freq.
Timing (when available)
I would love to see what the ECU does with timing since as far as I know there has never been a product made for our cars to monitor it.
again, see
http://www.maftpro.com/info.shtml for a list of what parameters you can log.
yup, i can't wait to see what the ECU does w/timing vs. % AFM scale. heck, i'd love to know what sort of timing it's putting out @ max flow....
Blue87T(Dan) said:
When do you feel code for the ZT will be available?
probably w/the next release of the software....
Blue87T(Dan) said:
When do you feel the timing control option will be available?
this will take some more work, i'm going to guess early next year if we can do it.
Blue87T(Dan) said:
Will the A/F autotune function be something that can be activated at a given TP while letting the ECU do the work in closed loop?
that's exactly what it is, see maftpro.com
Blue87T(Dan) said:
Will you or FTS offer a replacement pipe(with the proper ports and vacuum fittings) since when running speed density both the accordian hose and AFM can be eliminated but I would prefer to have my air filter as close to the snorkel hole as possible.
not to my knowledge. we may look into that if demand is high enough (HINT HINT...i.e. BUY 'EM!).
Blue87T(Dan) said:
Will there be any way to set it up to trigger fuel cut at a given boost pressure since not all of us want to eliminate fuel cut?
yup, that will be in the next software release or soon there after...
Blue87T(Dan) said:
I assume my 3.5 bar sensor from the ZT would work since you are also using a 3.5 bar sensor.
as long as the scaling/factors are readily available, yes.
Blue87T(Dan) said:
Sorry for all the questions.
Dan
no you're not!
