Making little bits of progress here and there.
But looking through the EPC, both the water pump page and the front plate page, which I initially followed when I loc-tited those studs in the front plate (around the water pump) So I'm not sure if i got em right, it doesn't seem like I did i think the stud's are sticking out too far for the nut to even reach down to the housing. And it seems like theres a bolt missing right behind the front plate... wtf is that for?
And some chipped paint.. i'm thinking of hitting some spots with duplicolor hi-temp, not sure if it'll just burn off, but I'd probably just get the freeze plugs... Actually I probably won't end up doing anything :biglaugh:
I also removed the cams from the head, it seemed like it was way to hard to rotate them, so i added fresh assembly lube all over, and then installed the seals and used some right stuff under the front caps. TSRM = My bible
With the gears on (had to drill out 2 opposing pin holes since i painted the gear and it wouldn't fit anymore over the pins) It was pretty hard to turn! Probably almost the same as the crank with all the pistons in. I'm guessing it's just the resistance from all the valve springs, is this normal?
I know I'm missing on bolt on the right of the plate, it was backordered. But it doesn't look like it'll be a 10mm, the TSRM says to use sealant on the 10mm bolt, but there aren't any...
