Finally some progress today! my crank spins freely, all my clearances checked out, My oil pump is below standard clearances, and the pressure relief valve doesnt fall to the bottom under it's own weight as stated in the TSRM, i'm thinking everythings ok, also, i only have a 40-200 ft/lb torque wrench, do i really need a in/lb to torque the oil pump? Or is 'tight but not too tight' good enough? I don't want to half ass things here but it seems like it would be alright! I also assembled the rods and pistons, now i need to wait for some more parts.
Question about the freeze plugs, i know 2 of them are supposed to be screw in, and have a gasket, i coulda sworn i ordered the gasket for it, i have the 2 small plugs and they don't have threads, neither does the block, is there a gasket i need to order for them?
Now i have to wait for a toyota gasket set, 1 more freeze plug that got lost in transit somehow last time, and some other misc. parts. And i noticed some small scuffs in my thrust washers, these aren't that sensitive are they? Seems like it should be ok, but this is my first assembly job, what do I know?!
Man i really need to get some new batteries for my camera!
If anyone has a set of oil squirters for sale, i need them bad!
