Update:
Brake booster and master cylinder installed, I spent about 45 minutes making a gasket for between the booster and the firewall, and then later I found the one I had a feeling I ordered :biglaugh:
So as far as the engine bay goes, the brake & clutch lines are done. Still need to finish installing the SS brake lines in the wheel wells, not sure if I'm going to reuse my stock calpers, I need to order rotors and brake pads. then it will be back on it's wheels again!
Still need to weld in a ABS connector that was damaged.
Finished the passenger side AC Lines, after a little bending back into shape.
Fuse box and wiring harness is all getting back into it's original position, igniter back on, still need to figure out oil cooler and filter mountings, not sure if the dual filter mount will fit under the driver or pass side headlight (still using stock IC piping for now)
Pictures next time I get some more done
