Jaguar_5;1103750 said:
Have you actually adjust the TPS via the TSRM using a feeler gauge and ohmmeter?
If you can adjust the TPS according to the TSRM, then you have the correct one, if you had the wrong one the tabs wouldn't even engage and the resistance won't change
Jaguar thank you for the help, read post 78 as for your answer.
Back on topic. Here are the results from reading ohms at the ECU.
My reading at ECU TRSM reading at TPS
VTA-E2---2.1K .2-1.2k
IDL-E2----2.49k (CLOSED) < 2.3k
IDL-E2----INIFINTY (OPEN) Inifinty
VTA-E2---7.49K (FULLY OPEN) 3.2k-10.3k
VC-E2----8.7K 4.25k-8.25k
Readings at TPS with sensor removed
VTA-E2---105
IDL-E2----51 (CLOSED)
VTA-E2--- 6.17K (FULLY OPEN)
VC-E2---- 6.87K
So here is what I see from these readings, no broken wires.
As outlined in TSRM with sensor removed everything check outs OK
86-88 sensor I am using from tubbie I am has part #89452-14050 brown label
(this sensor dose not work with the TB) The 89+sensor I also have from this engine originally has close to the same readings. That TPS has part # 89452-20050 with a blue label
With both sensors I have code 41.
Pics. 89+ is on the LEFT (blue lable)
Here you can see the 90 degrees differance between the two. Again 89+ is on the left
Anyone on board with me thinking this "custom made" TB is no good. And I need to get a 90mm or 100mm TB that wasen't hand made? OR just need to find another TPS from a 86-88 turbo?
