since the valve covers are off it should be really easy to spec out the shims per TSRM with a feeler gauge
92nsx;1083438 said:They are easley removable at least now with ffim. I will search TRSM for specs. But never the less I want to wate for Jim to ok everything/ look it over before I start doing things my self.
CyFi6;1083462 said:You connected the timing light to cylinder number 6 correct? And not cylinder number 1.
hottscennessey;1083512 said:Specing it out will only help to answer your question of why you're pulling little to no vac. It will not change anything (I wish it were that simple).
All you need is a feeler gauge and to follow the steps in the TSRM (starts on this page)
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=8
Doward;1086637 said:Suggestion:
1) Take off the intake, and verify ALL surface flatness with a machinist's straight edge. You don't want to fight a leaking intake.
2) Do you have adjustable cam gears? Open up the LSA a bit - that'll smooth your idle. Ian, what is your current LSA with the 19" of vacuum?
hottscennessey;1086639 said:spec those shims yet?![]()
