gilberjj said:if you consider shot peened insides stock......
It is only the forks that are shot peened
yes, 2nd-4th gear.gsmokez said:When you ran 11.72 on the 1/4 mile did you use your nitrous?
Hmmm, I just ran an 11.62 on a stock R154 that has bad syncros and a slipping clutch.gsmokez said:ohh aryte and is your R154 transmission stock? Because my friend, an Eagle Talon owner, was telling me how theres no way I can run 11 seconds on a stock R154 transmission
shaeff said:tell your friend to take his crank for a walk... unless it already took itself. :sarcasm:
suprarich said:Drag radials like M/T ET streets.
You really only need about 370 to 400 RWHP to run into the 11's on a full weight 5 speed mk3
buldozr said:http://209.190.111.111/Stupid/crankwalk.jpg
http://www.roadraceengineering.com/eclipsetech/crankwalk/crankshaft-caughtwalking.jpg
hehehe, the 7bolt crank was the result of a bunch of mitsu engineers that thought it would be funny to machine crankshafts still hungover, reaking of cigarette smoke and cheap saki. :nono:
well the 11.72 run was with nitrous, but I dont doubt that if it had a better tune and I had more practice it could see 11's without spray. I was running 12.2ish at 115ish without the nitrous. Swapping in an automatic transmission wouldnt hurt either.starscream5000 said:Truth. As demonstrated by s turbo 87
http://www.supramania.com/forums/showthread.php?t=57486gsmokez said:why? whos s turbo 87? any videos or info bout his car's mods and stuff?
And nice crankwalk picturelol
