AF1jZ i did this last night @ my job with the motor OUT and it was still a bitch. GL Bro!
before
after
also replacing the p/s pump & took off the ac compressor.
p/s i didn't like the gaskets provided as it was the same thickness of 1 gasket and they were two on each of my twins, so i used one all metal and the gasket provided by with the y pipe, i should have probably used both metal ones but o well. its all tightened and i don't want to take them off again.
before
after
