Tanya: For a Mk3 if it's less than 7.0L na I'm not interestedTanya said:It won't be anything you guys would be interested in putting into your mk3s, but fun n/a power anyway![]()
It's a lot of money and time. The second time is always easier.Ma70.Ent said:Haha. Imagine a super stroked N/A.
DEFIANT 7M said:It's a lot of money and time. The second time is always easier.
Not just talk, my stroke is 97.5mm with +.060 10.5-1 pistons. You can go .060 over with the right block.Tanya said:There was talk awhile back about making a stroked crank, not sure whatever happened to that. It was like a 97mm stroke IIRC. I calculated that a 97mm stroke with a 84.5mm bore would be a 3.3 liter engine, lol. But that bore is MAXING it out at .060", if you can even go that far.
CRE said:I agree, I just operate under the assumption that people aren't going to use common sense... something demonstrated all too often. I wasn't trying to say you were wrong, but merely clarify what I thought needed to be for all those special someones. :naughty:
Let's play this another way... which is lighter? GE + W58 or GE + R154
The stock airbox IS a cold air intake... have a close look. It's not terribly restrictive either. The only thing that kills the stock airbox ir using cheap, poorly flowing filters in it.
Now the VAF, that's another story...
Lightweight flywheel will help reduce losses, doesn't actually make any more power but helps you see that a little more actually make it to the wheels.
Is a stage 2 clutch really any lighter? If not don't bother, You haven't done a thing yet to actually make more power... the stocker will work just fine.
A couple other helpful things are: lighter wheels, one piece driveshaft, new gear oil in the transmission and diff., maintain proper tire pressure, get an alignment (even if it "feels fine"), replace the forward undercoverS (there are 3).
If you want to go overboard: new wheel bearings, check brake pad clearances when they're free, check the clearances of the parking brake pads when free.
Then, I'd probably start the mods with deleting the VAF... I hate that thing.
Ma70.Ent said:There are some problems associated with that stroker kit. I think figgie/adjuster/IJ know, so you should send them a PM if you're going to use it.
labrat469 said:Modifying motors comes down to two words. Acceptable risks. How far are we willing to go to risk engine life and reliabiliy for the sake of HP.
labrat469 said:I'ver read the article on another forum about the piston speed. That's why I went with a mild .010/.010 stroked crank. The crank in my motor is the lighter 6M crank. It's a risk I'm willing to take.
When modifying a motor you decrease the longevity and reliability of the motor. Toyota spent years designing and building the 7M and we in the matter of hours throw all their R&D right out the window. Modifying motors comes down to two words. Acceptable risks. How far are we willing to go to risk engine life and reliabiliy for the sake of HP.
Adjuster said:Well, after running the "Stroker" as delivered from Flatlander for about 350 miles, it crapped out, and I ended up re-building it again. (Combination of a soft set of pin bushings, and Flatlander's total screw up on ordering the parts, and then not owning up to their screw up's...)
So, with the crank re-worked again, and the journals hard chromed and then ground true, and Pauter using hard bronze pin inserts, the motor has now held up to some regular abuse and use with not too many problems.
If I was going to do it all over again? I'd either just do something simple like convert this car to a LS3 based V8 with twins and standalone ECU, or get lighter pistons from JE, still do the coatings, and the oil system and all the other mods since the 7M Stroker motor is really fun to drive on the street, and make's silly amounts of tourqe on a mid sized turbo. (Spell that tire smoke at will in the lower 3 gears.)
figgie said:Hey Anthony!
No need to. I am here also Sorry about the delayed response I don't come on here to much.
This is just my experience with them.
I had no issues at all with them (Import Performance = Flat Lander Racing). Adjuster on the other hand did have issues with them. Though the difference between me and adjuster, IP did the complete short block for me, Adjuster got the parts sent out for coating and then back to adjuster and then sent to his engine builder. Though IP did double charge him (CC).
There was one issue that thankfully I caught and advised adjuster on and that was that with the stroker kit using the Pauter rods, the Oil pump drive shaft HAS to be machined smaller to make room for the pauters spinning.
With that out of the way.
The Stroker kit is good but it is also worthless (contradictory I know)
Unless you are doing a full blown stand alone with Traction control (and by traction control I mean individual wheel speed like A MoTeC not the AEM). The stroker motor alone with the new stroke becomes a smoke show for the first THREE gears at ANY speed. Traction control is a MUST unless you think that smoking them uncontrollably at 65 mph is a good thing and believe me it is not.
IJ. said:^ Oil pump shaft needs to be machined even at stock stroke if you're going to rev it hard with Pauters
IJ. said:Yep I was getting some weird chatter marks on #1 and #2 crankpins and finally traced it to deflection above 8000 was letting the rods just touch the shaft!
I also machine the old mechanical fuel pump cam off the shaft in case that was making it whip.
figgie said:how much did you take off the oil pump shaft?
IJ. said:From memory it was 1.5mm off the diameter.
labrat469 said:FA one piece driveshaft is asking for trouble when you take in consideration the rear suspension travel. One pieces are restricted in movement and can cause more trouble than it's worth. As for a lighten drive shafts I wish I still had mine from my 1974 AMC Javelin. The motor-trans combo had enough power to twist the shaft and turn the rear diff into a grenade.
Peace and Engine Grease
iwannadie said:I love anti-na people, yes going turbo is a more cost effective to get power. Guess what, the supra isnt the most cost effective car to be getting power out of to begin with.
