89supturbo said:
1. 2j's have held more poower than 7m's have its not debateable its just the truth
really?
<-- apparently HKS was running a 2jz then!!
89supturbo said:
2. I removed my 7m head bolts with a 10mm hex rachet plus no one makes an L19 headbolt for the 7m
congrats, that is the correct allen head measurement but the thread itself is 12mm x 1.25
so you were ALMOST correct
When a bolt is measured, the pitch of the thread and the diameter of the thread is what is explained by the numbers i posted.
89supturbo said:
3 and 5. it could be that everyone but you is retarded in this community or it could be that toyota made an engine that flowed more oil using new technology on the 2j
you would be suprised by the amount of stupidity and the things that are taken for granted until people are EDUCATED on such trivialties. Funny that it is not only me, DrJonez, IJ., Adjuster, all the old crew, never had any oiling issues, bring in the rookies and look at that, rod knock problems. funny to say the least.
89supturbo said:
4. if you dont like AEM there are many other options, many people have done very well with it however and it has absolutely nothing to do with an engine debate but for the record there is a 7m AEM/
and there is a megasquirt 7m too.
You can polish a turd but it is still a turd.
89supturbo said:
6. the rods are better theres a side by side comparison in arrons 5m 7m build thread and again they've held more power
I am a man of science. Side by side is just like a butt dyno. Influenced by Placebo, get some measurements for psi failure, stress areas, and all that good engineering "stuff" THEN and only then we can talk.
89supturbo said:
7. lets see some flow sheets, his head v. TMS stage 3 race head
get them yourself. Search in SF for allan"defiant7m"sterling. Please notice the part in quotation as he did that with a purpose.
89supturbo said:
8. if its oiling is better it can spin faster
hmm odd that you say that.
Bernoulli meet 89supturbo
89supturbo meet Bernoulli
now on to why this gentleman is important to the oiling system. Not only did toyota do the 7m oiling correctly it was actaully downright INGENIOUS.
See, pressure is bad. Pressure is a RESISTANCE TO FLOW. Pressure also equals to higher overall tempratures
According to Mr. Bernoulli, as VELOCITY of a fluid rises the pressure decreases or said another way, as Pressure INCREASES velocity decreases. What does this mean in english and for oil systems? Quite simple actually, if you have a high volume at high pressure, then the velocity (total FLOW) of that said oil through out the system is LOW (meaning it takes 3 seconds from pump to main bearings, etc). Now lower the resistance of the oil system and now you have high volume at HIGH velocity (which means 1 second from pump to main bearings etc) get the oil in and out of where it needs to go quickly. Here is the ingenious part. Toyota knew this and decided to do a HIGH VOLUME, Low Pressure oil system on the 7m instead of the Low volume High pressure!
The myth that keeps on getting tossed around is not only flawed but incorrect.
89supturbo said:
you seem to be the only person that has had enough luck with your 7m to say that its better than a 2j while the majority prefers the more technically advanced 2j so why are you asking him for facts your the one trying to debate the established rules, BTW you wouldnt happen to have any ASE patchs would you figgie?
only person? nope, plenty of other folks that have had no issues either, just they don't waste time with these sorts of threads as they are always the same ignorance displayed
It is that Giant wave of stupidity that always pops up.
as for ASE. Hell no.
