P5150,
Did you have the block resurfaced prior to the new HG or did you only resurface the head?
p5150 said:Just in case you are wondering how the stock rods hold up, it looks like a GT42 running 35psi and pushing a Ford Probe into the low 9s (yes I know it sounds wierd) finally did it in.
http://www.clubna-t.com/forums/showthread.php?t=2912
When i was all into mazda mx6 he was using a FE3 engine dohc basically the vtech engine of mazda. most tunners say fe what_ good engine though.I was about his whole set up for 3k. motor ecu lsd etc. BUt I just found a 2jzge off of a gs300 for 270 dlls with wiring harness, ecu87matt;514415 said:I remember when that car was fwd, pushing over 400ftlbs and running low 11's. matt is a great guy and to this day still holds the record for the fastest fwd (street legal) probe. now with the 2zj in there he has the fastest RWD probe. he says he still takes it out on the road, glad I don;t live around those two. :nono:
back on topic I would love to do this swap. I'm happy with the 7m for now though.
