heres a teaser pic i was sent before they were wrapped up ready to send
spewign they 6 weeks away
Uploaded with ImageShack.us
customs;1556919 said:So quick question. I am curious to see if I have to worry about these wheels rubbing on my coils
18X9.5+30 front and rear.
The car is lowered as it is. I know fender work maybe needed but thats a big deal. just worried about the coils.
customs;1557504 said:Does anyone have some input for me?
te72;1557635 said:I have 17x9.5 +50 all around, with 275/40's on them, they don't rub at all. Stick that 20mm further toward the outside of the car... you're gonna be fine. Should look pretty good too, at least in the back. Not sure about the front, they *might* stick out a bit.
zodiacmouse;1558063 said:17x7 with a 40 offset. will clear everything good right? or would i need wheel spacers.
Why were you running drag radials on the front of a Supra? Do you just not like turning very much? :icon_confChard;1558333 said:What would be a good tire size combination (front & back) plus spacers for the mkiv tt wheels? Originally, the front tires scrapped heavily when it had DR's 275/40/17.
I have Eibach springs with KYB struts all around.
Tires don't rub the fenders, the wheels do rub the control arms (or something on the inside) if you try to do u-turns too sharply, but that's easily avoided. Only mod to the car related to the wheels/tires is Megan Racing coilovers...Cz.;1557924 said:You've got 275s in the front and they don't rub? Did you pull the fenders and do other mods?
te72;1558834 said:Why were you running drag radials on the front of a Supra? Do you just not like turning very much? :icon_conf
te72;1558834 said:Tires don't rub the fenders, the wheels do rub the control arms (or something on the inside) if you try to do u-turns too sharply, but that's easily avoided. Only mod to the car related to the wheels/tires is Megan Racing coilovers...
91T breezen';1559330 said:This is because the MkIV offsets are 50MM!!! To keep this from happening, you need to get those 9.5" s out there to about a 30mm offset. Then, roll your fenders and run a 255/40 on the front, and the 275/40 on the rear (w/ the 20mm spacer also)
Problem solved, look achieved!
MKIII TURBO60-1;1561000 said:anyone run 18X9.5 +25 front and rear, thinking about running another set of wheels. If i have to pull and roll fenders (two thumbs up)
