Wheel Fitment & Question Thread
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
SupraJDS;1184843 said:
Will these fit good?
Front: 18X8, offset 20 Front tires: 235/40 BF Goodrich g-force t/a kdw
Rear: 18X9.5, offset 35 Rear tires: 275/35 BF Goodrich Drag Radials
Thanks,
Josh
rodel;1184870 said:
You'll be fine.
Uh oh! Sounds like someone is looking at TSW's! 18x8 f will rub both the inner fender liner, and the wheel well edge, unless you roll the fenders! I had that same setup on my car, and currently have 17x8's that have a 20mm offset via a 15mm spacer. They were rubbing badly over any sustained compression at freeway speeds. Had the fenders rolled, problem gone!
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Looks like this thread is going alone nicely. I haven't been on here much with school and work but it seems like a few of you are keeping this a live very well.
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
Hello All,
Looking @ 2 different set ups:
1) 18x9 +30 offset front w/ 18x9 or 10 with +20 offset rears
2) 18x9 +30 offset allround with maybe a spacer in rear.
Will this work and what tire sizes do you guys recommend.
Thank you,
Jim
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
Warpath;1188992 said:
Hello All,
Thank you,
Jim
BorHor;1190187 said:
Sure they would all fit.. But it it is all up to the tire size you want to run as Sawbladz is basically saying.
Thats my problem (next to drinking) i'm not sure what tire size to run. I'm looking for something that won't rub badly in the front and in rear.
Thank you,
Jim
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
With a 9 or 10 +20 you will only be able to fit maybe a 245 in the rear my guess is less without extensive rolling. If you go with the +30 in the rear I think you can go up to a 265 or 275 in the rear.
Warpath
Help me Jeebus!!
Oct 28, 2008
135
St.Louis
Thank you for the help, I appreciate it.
If i go with a 18x9 +30 in the front what tire size would you reccomend?
Jim
Sawbladz
1,727
Oshawa, ON, CA
I would say 255.
EDIT: Just to add to this. Upgrading to an 18x9 with this size of tire will drastically affect your braking performance on stock brakes in a bad way. This combo will be heavier than what it came with stock and the stock sized rotor and caliper will have trouble keeping up. They will fade faster and stop longer. Keep this in mind when considering wheels.
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
ok new setup that im consider buying is not a 20 offset any more there are
18x8.5 with a 32mm offset in the front and 18x9.5 with a 35mm offset in the rear,
Which tire sizes can i run without rolling the fenders?
i was thinking off 245/40 up front and 275/40 out back
ps im on eibach springs
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
reaper_mk3;1190978 said:
will these fit the mk3 stock suspension height.
+35
18x8.5 235/50r18
18x9.5 255/45r18
thanks
245/40/18
255 or 275/35/18
Would be ideal and your going to eventually wanna lower the car afterwards.
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
Supraboostin;1190986 said:
what tire size will fit in the front with a 18x9.5 +30?
Judging by your sig that your car is lowered fairly well I really dont think 18x9.5s would fit up front without having some kind of rubbing issues. 8.5s would fit nice with a 245/40 tire.
queenskid926
Jul 27, 2007
1,112
New York City
wat tire sizes would be ideal without me rolling the fenders? I was thinking 235 or 245/40 up front and 275/40 in the rear, maybe a 35 tire in the rear
