Wheel Fitment & Question Thread
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
Sawbladz;1193622 said:
Rear tire should fit no problem and you will want to get the 35 aspect sidewall. For the front the 245 will work great.
ok im ordering some now, 275/35 for the rear and 245/40 up front, or would it be wise to get a 35 up front two? thank you for your help
Ron
Island_Yota
264
Vancouver Island
Ok theres a cheap set of wheels up forsale locally, thinking about getting them just so I can ditch the saw blades.
They are 16"x7" Enkei RP01's, +35 offset, 5x114.3. Just checking to see if those will fit alright, my guess is thats pretty much the stock fit? Anyone got a pic of these on their Supra?
Look pretty much like this:
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
I really like these rims at tire rack.The brand is Breyton,wheel model is the magic racing.They are BMW exclusive wheels,they only list them for BMW models.By any chance does anybody know a model of bimmer that runs the same bolt pattern and similar offset to the mk3's?Want 18's by the way.
cool chuck
I like rims!
Nov 15, 2007
179
Maryland
If I'm correct, BMWs run a 5x120 bolt pattern. You would have to use an adaptor to run that wheel.
Sawbladz
1,727
Oshawa, ON, CA
http://i10.ebayimg.com/01/i/000/eb/44/28dd_1.JPG
Should fit exactly like the stockers. Will seem to be a little sunken in if the car is lowered.
Island_Yota
264
Vancouver Island
Car is stock height, well the rear is a little sagged out but yeah.. Do you think that style of rim would look goofy in a 16" on an MK3? im starting to think it would.
Sawbladz
1,727
Oshawa, ON, CA
I don't think it will look "goofy" but I don't think it will give you the results you want. If I were you, I would look at some of the cheapish 17" wheels with a bit better offset and some more width. It will cost more for sure but in the end I think you will be happier. Plus you won't be spending money twice if you find out you don't like the 16's.
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
That's what I was afraid of,I run adapters on my cressida to fit the 18's,but I rarely run that car above 80 mph.Not really sure about trusting spacers/adapters at 100+
queenskid926
Jul 27, 2007
1,112
New York City
ok i have a friend that plan on running 19's but hes not on the forums,
his setup will be 19x8.5 in the front 32mm offset and 19x9.5 in the rear 35mm offset, basically same rims as mines but 19's
without rolling the fenders wat tire size do you guys recomend for the front and rear
rodel
SoCal
May 19, 2005
2,266
5
SoCal
235/35 front
275/30 rear
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
Warpath;1198539 said:
Would 18x9.5 w/+38 offset allround work? Lowered on h&r springs, what tire size would work?
Thanks,
Jim
Rears yes, fronts no they are too wide especially for 18s and riding on h&rs. I would get 8s or 8.5s for the front if available and run a 235 or 245/35 tire up front and a 275/35 in the rear.
SupraJDS
603
Fronts-17x8+30 tires- 225/45/17
Rears-17x9+36 tires- 245/45/17
Will these fit/ look good? What tires would fit the best?
btw wheels are 17 Work VS-XX's in gold
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
They will fit good with no issues. You can go with a lil bit meatier tire like a 235-245/45 up front and a 255-275/40 in the rear.
