Do you think 225/40/18 with 40 offset on Front and 255/35/18 40 offset on Back will go on without any rubbing, on 7.5 wide rims
Jackson;1084776 said:Do you think 225/40/18 with 40 offset on Front and 255/35/18 40 offset on Back will go on without any rubbing, on 7.5 wide rims
BorHor;1084784 said:Yes.. You didn't have to PM me about it.
Wiisass;1085449 said:255 is way too wide for a 7.5 if you want the car to feel like anything other than mush while you're driving. Either get wider wheels or deal with the fact that you have skinny wheels and can't fit a big tire.
245/40/18 should be good.Jaychen;1091508 said:Can anyone help me with fitting issues. I am looking at 18x8.5 +38 or +35 (cannot remember which one it is) all round. What tyres would I need to get so no rubbing occurs. Will they be alright with camber etc?
Krister;1086306 said:So I was thinking of getting new wheels for my MK3 and I'd like to get an agressive setup. I dont mind running camber, rolling the fenders and a small pull.
Here are the dimensions the rims come in:
18x8 et+30/+43
18x9 et+30/+38
18x9.5 et+15/+23
I was thinking 18x9.5 Rear ET23 and 18x9 front ET30. Or do you think I could get away with 18x9.5 ET15 Rear and 18x9.5 ET23 front? The latter wouldnt be a staggered setup, but does it matter?
What tires should I run with either?
SUPERIUM;1088262 said:18x8 et+30, 18x9 et+38 would be ideal with 245/275/35 tires. 18x9.5 et+15/+23
just won't work without running into rubbing issues, negative camber, etc for all around driving.
18x8 et+30/+43
18x9 et+30/+38
18x9.5 et+15/+23
Jackson;1085619 said:Thanks for being so helpful, maybe someday Ill be as smart as you and I can return the favor when you ask a question.
Thanks again
BorHor;1091514 said:245/40/18 should be good.
Jaychen;1091741 said:so 18x8.5 +38 on the front
18x9.5 +38 on the rear (with dish)
245/40/18 all round would be alright without getting the guards rolled?
BorHor;1091522 said:Depending on what kind of look you want you go with a different set up. For a easy set up I would go 18x9 +30 all around with what ever tire size you want. If you want you can do a 18x9.5+ 23 in the rear but you can only fit a 245 or maybe 255 with a flat roll in the rear. +15 can work too but that is a 225 or up to a 245 in the rear max. It all comes down to how fat of a tire you want and what kind of look you are looking for.
JByrd43;1092004 said:i need to know how 18x 8.5 w/ 20mm offset front and 18x 9.5 w/ 25 offset rear will fit. will they stick out at all?
Krister;1092014 said:Thanks for the advice. I think I'll get the +15/+23 setup and just get overfenders if I cant get them to fit without them. Narrow tires doesnt matter, they are even cheaper![]()
JByrd43;1092029 said:18 x 8.5 w/ 20mm offset
18 x 9.5 w/ 25mm offset
will they fit with no rub?
also how exactly do offsets work? smaller offset more pushed out or in wheels are?
