oh ok, well i'll figure that out once the head is off. I have a few more questions now;
Right now I got the exaust manifold brace unbolted and it will move over, i discovered that the broken stud caused an decent exaust leak...fried part of the gasket and there is considerable carbon on some other cylinders. just thought i'd share.
I need advice on this though, I want to change the timing belt while i have it off but it says i have to remove the main crankshaft pulley AND i need a SST to do so... do i really need to remove that pulley? if so is there another way to work around using the SST or can i use something else? I dont think i have the tool...
What's VSV? it says to watch out for that in head removal. I found something online called a Variable Stator Vane, but dont know what that looks like.
I'm going out now get it to TDC, loosen the head bolts, and remove anything that might hang up on the head when i pull up, such as fuel tubes and cables.
i'll check back in a bit.
