supramacist said:Low and behold....., six is shot to hell. She's gone down like well nm. BHG
Sorry to hear about your dad, I hope he is doing better than either one of our cars.
supramacist said:no......it's heavier than you think it is and you don't know what your valve seals look like. Lift it straight up and it will take you and one more. It's awkward to say the least. If you can't remove the manifold get a third person. You can't really pick it up and sit it down to regrip, you have to go to an alternate location fig.
jazzsaxman1988 said:Um. I just pulled the head off my supra for a BHG and I lifted it off by myself. It's really not that heavy. Take your camshafts off and you won't encounter a problem with your valves because they'll all be well out of the way. My head is in the machine shop right now- I'm having it reground and also redoing the valvetrain. This way, I know that I have a while before they're in need of it again. Um- P&P will do some for you, but there isn't that much HP gain to be had in NA motors... Up to you, but in reality it's not going to do that much for you in the way of power gains. Best of luck!
there isn't a real need to remove the cams unless you strip a headbolt or plan to do the valve job. If the motor missed at all before, it'd probably be a good idea to go on and take care of the valves now.Figit090 said:thanks for the info, i'll get it off then! I havent gotten the timing cover off yet and i doubt i will remove the cams if i can help it. I dont know if i'm going to do a valve job, if it needs one then yes but i think it might have been done now that i think of it; i need to see the records.
nope. No bushings. All it is is a piece of metal machined to the correct diameter. It's really easy to take the cams off. Just follow the correct bolt pattern and you'll be fine.Figit090 said:for machining, i dont have to remove the cams do i? i'd rather not if i dont have to. unless it's an easy unbold/rebolt process and i wont get any stippage or have to replace anything. i take it there are just bushings in the clamps over the camshaft? by clamps i mean the things over the cams with two bolts holding them to the head.
jazzsaxman1988 said:there isn't a real need to remove the cams unless you strip a headbolt or plan to do the valve job. If the motor missed at all before, it'd probably be a good idea to go on and take care of the valves now.
supramacist said:these stripped head bolts...., were they just missing threads on the bolts them selves????
supramacist said:You are going to want a die grinder and a 3 inch brass wire wheel to remove head gasket residue, when you do get it pulled. Some castrol superclean and the economy can of wd40. Probably a can of rust penetrant as well. Some scotchbrite.
