~sighs~ Well the car is ticking me off... Nothing big but the little things that are left on the car are bugging me. Im really starting to think about looking for another form of transportation so I can get back to trying to properly fix the car. It seems that the clunk I keep hearing going from neutral to 1st and getting off the clutch is getting worse (or louder anyways). I suspect that the clutch packs in the OEM diff are giving out due to wear and have caused a slight amount of play. Have a spare diff that Id like to inspect to see its condition. Hopefuly its not bad. Might take it appart and rebuild the diff to try to eliminate that little problem. Also have to hunt down and see wtf all these little squeaks are comming from when i go over little bumps on the road. Still have no a/c so thats a bit of a drag. It gets annoying driving around in the hot florida weather and having sweat drip down your back (or pretty much anyplace it can trickle down). The lack of shoes for the rear brakes is also pissing me off. I dont like leaving my car in gear when i park it. Would much wrather leave the hand brake up and thats it. Only way i seem to be able to pull that off is by parking in reverse on a hill and even then sometimes the car will start to roll. i have diff leaks, i have tranny leaks.. I have leaky valve stem seals that cause me to burn a qt. of motor oil every week. Seriously, Its getting irritating. :: rant3 ::
