AaronB;2058591 said:Is the R154 trans made from aluminum or steel/iron? Want to make sure I get the right type of washer with the replacement drain plug.
Casings where drain plugs screw into are aluminium for both drain & fill plugs...
drogon;2058395 said:So I'm going NA-t finally pulled the old NA block went to put my engine mounts on the new block still an Na but the turbo manifold support bracket seems to be in the way. Is there a diff between turbo and non turbo mounts?! Everywhere I read says no just the years(square or round). Or maybe I place the bracket incorrectly?![]()
code 32 I thinkhvyman;2060077 said:Could be the wiring for the afm.
What code was it?
Doat;2060082 said:code 32 I think
drogon;2060647 said:If removing clutch fan and aux fans can I remove the ac coolant sensor without tripping the ecu? I'm wanting to install a bmw switch for my Efan set up
thanks Cinder, I'll look into that.cinderMK3;2060710 said:Doat I had a similar issue when I did my rebuild, My car didn't come with a PS pump so the valve that runs from ps pump to the accordion hose in front of the turbo had an opening and sucked air. It was crazy until I plugged it. After putting a plug in, the car idled perfect.
check for a leak or that check valve on the bottom of the pump may be going.
Also I guess while I'm here has anyone ordered a fan clutch from Rock auto? Mine has been intermittently sounding like a Jet taking off all the time. I know its normal and usually clutched around 3000 rpm or whatnot but it's been just full on lately.
I have had RO purchase before and are good, just looking for more info or previous buyers. or maybe even another supplier for one.
cinderMK3;2060710 said:Also I guess while I'm here has anyone ordered a fan clutch from Rock auto? Mine has been intermittently sounding like a Jet taking off all the time. I know its normal and usually clutched around 3000 rpm or whatnot but it's been just full on lately.
