Doat;2053453 said:
So I tried tackling my power steering issue and when I tried removing the banjo bolt on the pump the entire union bolt broke loose and there is no room at all to get a wrench on it to hold it while I break the banjo bolt loose. Also I don't know how the hell to get that hose and hard line out without dropping the subframe. Anybody have any tips or advice?
1. Remove anything prior to the turbo and hot side IC pippings, more importantly the pipes right after the turbo that sits on top of the rack and below the pump.
2. Remove that stupid PS line clamp. ( 1/4" thinwall 10mm works well here)
3. Remove the rack bolt down bracket and bushing ( this will give you enough room to slightly push the passenger side of the rack up to pull the line through).
4. Undo the banjo bolt on the pump and yes the banjo bolt fitting will want to move with the banjo bolt, you just have to find something to hold it in place to continue.
5. Undo rack side banjo bolt.
6. Once everything is free you can start pulling, wiggle the line towards the turbo, ABS module area. There should be plenty of room to do this and with the rack being loose and with some wiggle room for the rack you then can slide the rack end part of the line through.
7. Installation is of course just the reverse order of everything.
Good luck dude!
