buckshotglass
I love all your sounds.
Wouldn't it be cheaper to fly Big A to the car? It won't really matter because you will figure it out tomorrow for yourself. Just sayin' :cry:
Hell get Big a and his lady roxy both to come make him a sweet deal that they cant refuse .:evil2:suprahero said:I'm not real sure he is willing to do that, but if he was, I've got a plane ticket waiting...............:biglaugh:
If you can help me get Aaron over here then you're more than welcome to come also. And for the record, my wife is the best cook I know.buckshotglass said:mmm, I can smell Vixen's biscuits and gravy already. You are going to fly me in too, right?![]()
suprahero said:Well I had two of the wires on the coil pack wrong. Now it idles alot better, but it's still getting tooo much fuel. I'm getting the exhaust done in the morning (supposedly). I've taken 20% out with the afcII, but it still runs rich if I give it any gas at all. I haven't adjusted it for any rpm's above 2200.
The ecu is acting up for some reason as well. If I turn the key I don't get power to the ecu. I turn it off and try again. Sometimes it takes like four or five tries for the check engine light to come on showing me I have power. When it cranks, the check engine light goes off. It doesn't stay on like it has a code. I tried to check the codes today. I believe on the 1jz it's the TT and TE1 that you have to jump but there's no wire in the TT on the diagnostics. I will try and jump the TE1 and just ground it tomorrow and see if it throws a code. Wouldn't the check engine light be coming on though if I had a code?
Anyone know why the ecu is acting up? I did have the capacitors replaced, but a reputable TV repair shop. All he replaced was the capacitors so I doubt he messed anything up................:dunno:
Josh, that wire was laying on the ground by the clip. I didn't cut it but Ricky may have. I couldn't tell you where it went since it was already cut.
bigaaron said:I just found a round trip flight for $324, including a rental car, and I will put in $100 towards it. :naughty:
