Nice solder work on the core Dave.
I did like Toyota and used rubber o'rings. I hope they hold up...
CajunKenny;1626040 said:Nice solder work on the core Dave.
thedave925;1626965 said:I haven't seen anything fuse related in either manual. I'll double check the accusump manual...
4 amp fuse in 1) of EPC manual, last line practically.
" 1) Locate an accessory terminal in your fuse panel that is energized when the ignition is on. On applications without a fuse panel, an accessory terminal on the ignition switch can be used. This terminal should only be energized when the switch is on. If the lead is not fused, a 4 amp fuse should be installed."
^^^ Typing class, most useful thing absorbed from highschool, made paraphrasing that like a minute lolz
thedave925;1627316 said:I found your build thread Moy, I see about your EPC switch placement, it's convenient for the switch body.
i'm still determined to install it in the Coin tray thingy lol
