^^^ lol
I set the cam timing, started her up for the 5th time, fiddled with the loose cps while shooting the crank with a timing gun, and when I was happy I blipped the throttle cam.
Stood back as the tap tap tap of RK began and then the cartoon effect of a character slide-stopping, it was over in 1-1.5 sec.
Standing there absorbing what happened, I got really hot and my shoulders tensed up.
Then I muttered "Thats it. I can just about walk off a cliff and end up with a better outcome."
I put my tools away, locked the supra, turned on the Comp to type post 97. Fooled around thinking, typed another post and decided it was best to go do something.
Thats how I handled it.
I'm still irked, but its buried deep beyond the machine mentality that there was a failure, it can be fixed, and this is not a point to give up.
My bad dreams along the way consisted of my car ripped apart, I die or never come back for some reason, and NO ONE I personally know would be able to finish my project.
But life isn't a dream and both could change with enough effort, there is no turning back. This car will be done.
I think its an oil pump failure. How could the engine not see oil pressure after that many minutes in operation?
I did modify the pump in that I had shimmed what I was sure was the relief spring behind that side bolt outside the gear housing of the oil pump.
I'm suspicious of debris in the pressure oil galley that runs the length of the block.
Or that I hooked up the lines out of the filter adapter wrong.
And I'm sure the engine ran as long as it did since I primed the turbo with a 1/2 quart of 30wt oil.
I still haven't had a chance to really work on removing it. I'm supposed to be in Sac in 4.5hrs, and have work tomorrow to probably 4pm.
I'm anxious to have this done. And your right Kenny, I'm up beat because there's no use in being down about it.
She's been my joy/pride for 5 years, and I intend to continue along past this hard time.
In other news, the 944 has too much going on with it to catch up in maintenance.
I'll be removing its new 3" exhaust for resale at discount, stripping the audio equipment out, and giving it to the state since there is a buyout program for cars older than 89 here.
Even after tip top shape, I couldn't get 5k for it, so why put in that much time and 2.5k more trying to get to that point.
I'll feel better unloading it
Its still unbelievable that the engine could live so long without oil... I can't wait to see where I F'd up
