^keep us updated, seems the WG flap could be a more widespread problem given your buddy's situation.
Zazzn;1583204 said:Hey guys,
my buddy just put this turbo on his car his car seems really lazy, and doesn't boost much of anything until about 5000 RPM. It was at a shop and I was trying to help him out with tuning. We couldn't get more then 1.1 bar of boost even with the WG not connected to a VAC line.
After reading all about this I'm thinking first he has a boost leak, and second it could be the WG leaking air as well. His results at 1.1 bar was 356 WHP and 299 tq I think. Really really lazy power curve made peak power at redline.
Anyways, I'll keep you guys posted on what this turbo will do once we do a pressure test on the intercooler pipes. If that shows nothing the turbo will come off and I'll tell them to inspect the WG flapper and pre load it to about 15 PSI.
Good info!
supraguy@aol;1585361 said:So Paradox-
Given your experience with this turbo and its performance, and you had the chance to do it all over again-
Would you still stick with this T61, or go with a modified Ct26 (57 or 60 trim)?
paradox616;1568239 said:1) I had my exhaust from turbo back made on the car by a few guys i know that run a exhaust shop, divorced downpipe until the floor pan pretty much. as poodles said, stock is a horrible design, i got the flange lazer cut and a 3" pipe all the way to the end tailpipe.
2) don't use the bolts that come with it, they are weak and most likely will snap when you go to undo them after running for a while, use some high tensile metric studs and nuts, Correct about centering, i lined it up the flange and use a jack to support the dump pipe then tightened the bolts, the casting isnt too bad on the exhaust housing.
to follow up on the wastegate flapper arm sliding issues, here are some close up pictures, compare the flapper position in each picture and the circled section
Here is a picture of my setup, apart from my braided lines it tucks away nicely and could almost pass for stock.
paradox616;1585301 said:Pm me if you have any questionsI've got a pretty good result out of it, i get 1 bar boost in first gear.... sounds exactly like mine before we fixed it
i preloaded mine to around 10-12psi (10psi starts to open and fully open by 12)
Keep us posted and make sure you email CX racing and let them know. Check for flapper movement as well
Before we fixed the turbo I recorded a video of the issue, no one make fun of my Aussie accent
http://www.youtube.com/watch?v=LCEMLCFRwls
Nghty89;1585828 said:The only thing so far that is keeping me from running this turbo, is the wastegate issue. How difficult is this to resolve?
paradox616;1586057 said:Easy, i took the turbo, handed it to IJ and it was fixed
took no longer than about 10-20 minutes? He just drilled a hole through the housing on the flange surface and installed a grub screw, you only need to secure the outer bearing to stop the movement.
I guess if you're shooting for lower Hp it would be a good idea to fit a smaller turbo to regain responsiveness, My guess is ill get bored with 400rwhp and want 500rwhp.
Nghty89;1586064 said:What exactly is a grub screw and how did you use it to resolve the problem? I agree, the pictures weren't clear enough.
Nghty89;1586369 said:Don't start that google mess with me... lol I had an idea of what it was. So once you drill that hole, it has to be tapped? Or can this be done without a tap? We need good pictures up close of before and after from the fix, does anyone have these? I understand the concept and could do it, but I'm sure others (and myself) will benefit from more detailed pictures.
Nghty89;1586417 said:I understand. Like I said, I understand the concept, but lack a spare turbo laying around so I could look at the flapper design. Sometimes I understand things better when I can actually work on them and sometimes I work better through reading... this happens to be one of the physical ones. lol
Thanks for that, it does help.
CBatstone;1587865 said:Paradox has taken great photos in this thread already that show exactly how the outer bushing moves up and down, changing the alignment of the flapper over the wastegate hole. I had thought that a small tack weld would accomplish the same thing. If it was not lined up exact when the tack was made, it would cause issues that would be more difficult to resolve. Thanks for the details on this fix, the T61 turbo is sitting in my room waiting to go on the car in early August.
